Backup run options
Old   August 30, 2007, 11:18
Default Backup run options
Felix
In the Solver Manager, manually clicking on the Backup Run icon doesn't write the residual variables (U-mom, P-mass, etc..) in the .bak file. Does anyone know where that option can be turned on? I suppose I just have to enable it as for automatic backups, right ?
Regards,
Felix
Old   August 30, 2007, 11:58
Default Re: Backup run options
CycLone
There is an option on the same panel to include the residuals but they aren't necessary for a backup or a results file. However, it is sometimes useful to include residuals so you can check out where the solution is not converging.
Old   August 30, 2007, 18:32
If a run is already going without the include residuals option but you would like to include it then try "edit run in progress" and add the include residuals option and save a backup.
Old   August 31, 2007, 09:18
Felix
Thanks for your answers but there is something I might have misunderstood. In PRE, in the Output Control/Backup panel, I've selected "Output Equation Residuals" (All) but let the "Output Frequency" to None. In the SOLVER's edit-run-in-progress, I can see Output Equation Residuals : All.
Still, I cannot visualize the residuals in POST when I open xx.bak... What did I do wrong ? Should it work as I set it up ?
Thanks again and sorry for bothering you with such a simple question,
Felix
Old   August 31, 2007, 09:49
CycLone
Hi Felix,
These settings only apply to the periodic backup file. By setting the output frequency to none, you are not getting a backup file with these settings.
If you want residuals added to the manual backup file you will need to add the expert parameter "output eq residuals". This will also include the residuals in the results file.
-CycLone
Old   August 31, 2007, 13:14
Felix
Aaaah !
Thanks CycLone, that explains it all! I hadn't notice that option in the expert parameters. Mea culpa.
I wish you all a nice weekend,
Felix
Error trying to run steady-state sonicFoam dancfd OpenFOAM Running, Solving & CFD 2 February 12, 2013 03:15
how to map results from steady state run to tranient case? phsieh2005 OpenFOAM Running, Solving & CFD 2 November 7, 2010 06:20
What's the best order to run this simulation in? siw CFX 1 November 4, 2009 19:42
Windows 64-bit, Distributed Parallel Run Issues... Erich CFX 3 March 28, 2006 16:36
Restatring run Tim CFX 2 March 3, 2006 11:54
