-   -   Turbogrid negative volume Come Back (http://www.cfd-online.com/Forums/cfx/24483-turbogrid-negative-volume-come-back.html)
jorge September 1, 2007 10:58
I have ansys turbogrid 10 in workbench environment, but this send a error when i want to do a mesh.(negative volume). I read many post about this(These advice move the master control points)but the problem is not solved. Help me.Please. Jorge
Dothan September 4, 2007 03:05
Re: Turbogrid negative volume Come Back
After set Topology, right click near the geometry: select "Transformation" and "Blade to Blade". Activate in the menu "Display" - > "blade to blade view" the option "Use passage transform". Now uncheck all geometry entities excluding "hub" or "shroud" in the group "layers". You will able to view all distorted planar elements. Bad elements in these planes lead to inconsistent 3D mesh. Moving master control point will help you to resolve problem. Before generate 3D mesh, verify the options inside "mesh data": too high or too low values can lead to inconsistent 3D mesh.
References:All these informations are inside the Turbogrid Guide.
Regards
