-   CFX (
-   -   cavitation impeller centrifugal pump (
mino2006 September 2, 2007 12:43
i am using cfx to calculate npsh requierd in a centrifugal pump but i meet a problem when i define the inlet statique pressure. i must fixe flow rate outlet and pressure total inlet with varring de statique pressure inlet ti obtain npsh requier
but i can't find at same time for boundary inlet total pressure and statique preesure
how can i do please
maxsanty September 7, 2007 11:35
Re: cavitation impeller centrifugal pump
you cannot put a static pressure with total pressure at inlet.
It is sufficient to vary the total pressure at inlet to obtain the NPSH af the pump.
NPSH= (Ptot inlet - Pv) / ( ro * g)
mino2006 September 19, 2007 12:16
thank you very much I have followed this procedure but when i reached the pressure vapor, normaly, i must FIND a drop of HMT with decreasing Pt but HMT remains constant it is not logical how can i do
