why the velocity on the wall isn't zero?
Like Tree1Likes
  • 1 Post By Felix
Old   September 4, 2007, 05:20
Default why the velocity on the wall isn't zero?
Wei Chen
hi all! I'm studying the turbulent boundary of the flat-plate now. First,the turbulent model I used is the k-epsilon, but i find the velocity on the wall isn't zero.(is about 7~8m/s,if the inlet velocity is 20m/s) Using the same grid ,if the turbulent model is the SST or k-omega, the velocity on the wall is right ,zero. I don't know why!
Old   September 4, 2007, 16:38
Default Re: why the velocity on the wall isn't zero?
Felix
Hello Wei,
I would suggest you to have a look at HYBRID vs CONSERVATIVE option. You can select one or the other option when you color a plane. The difference is well explained in the documentation and selecting hybrid should allow you to see what you want !
Also, pay attention when using the same grid for SST and k-epsilon. This is usually poor practice.
Regards,
Felix
lostking18 likes this.
Old   September 4, 2007, 23:18
Wei Chen
Felix, thank you very much! the problem is solved, and i find the velocity profile near the wall is too different from the Coles, SO ,is it the wall funciton is not suitble to solve the problem near the wall.
Old   September 5, 2007, 09:10
Felix
Hello Wei,
There are some good books describing the wall function approach and its validity. I suggest you have a look at Ferziger & Peric (2002) or Wilcox (1993).
If the behavior of the flow in the vincinity of the wall is important to you, try solving right through the viscous sublayer. Some k-epsilon models can do that, the k-omega too and the SST when you keep y+ < 2.
Felix
Old   September 7, 2007, 22:30
TB
I wouldn't jump into that conclusion too fast. Many factors will affect the quality of your results. Try improving your mesh etc... Refer to the user manual. Lots of tips there to help you improving your results.
Old   September 8, 2007, 08:33
Wei Chen
Felix,thank you very much ,i will do that as you suggested,
Old   September 8, 2007, 10:29
Felix
That's right TB, it is good to be kept in mind that the wall function is only one parameter among many others ! Solving through the viscous sublayer is not a miracle solution. It only allows to get computed results near the wall.
Felix
Old   September 12, 2007, 17:07
Felix
Hey up yours TB!
Felix
Velocity fluctuation distribution near a wall Matthieu FLUENT 1 June 3, 2021 09:40
[Commercial meshers] Fluent3DMeshToFoam simvun OpenFOAM Meshing & Mesh Conversion 50 January 19, 2020 15:33
the air velocity is not zero on the wall? Li Rong CFX 5 April 9, 2018 02:02
A girl fail to plot velocity profile when mesh changes + Wall function asherah STAR-CCM+ 0 February 19, 2010 17:45
display velocity at wall Flo FLUENT 1 October 22, 2007 09:24
