CFX Transient time step
Old   September 11, 2007, 13:23
Default CFX Transient time step
jorge
I need a advice for select a time step for a simulation in a centrifugal pump.Where i begin? What i have that consider for this?
Thanks,
Jorge
Old   September 11, 2007, 16:20
Default Re: CFX Transient time step
CycLone
To start, try a timestep that is at least 1/20th of the time it takes for one blade passage. The following expressions will return the appropriate time for a rotor with 11 blades at 30,000 RPM with 20 steps per passage
RPM = 30000 [rev/min] Number of Passages = 11 steps per passage = 20 timeStep = 1/RPM/Number of Passages/steps per passage or timeStep = 1/(RPM*Number of Passages*steps per passage)
You can then use 'timeStep' to specify the timestep instead of inserting a value, allowing you to change 'steps per passage' as desired.
-CycLone
SLTS+rhoPisoFoam: what is rDeltaT??? nileshjrane OpenFOAM Running, Solving & CFD 4 February 25, 2013 04:13
Problems with simulating TurbFOAM barath.ezhilan OpenFOAM 13 July 16, 2009 05:55
IcoFoam parallel woes msrinath80 OpenFOAM Running, Solving & CFD 9 July 22, 2007 02:58
AMG versus ICCG msrinath80 OpenFOAM Running, Solving & CFD 2 November 7, 2006 15:15
Small time step and CFX solver crashing Vanessa CFX 2 June 21, 2006 09:18
