-   -   Curvature Correction & Reattachment Mod. (http://www.cfd-online.com/Forums/cfx/24535-curvature-correction-reattachment-mod.html)
Felix September 14, 2007 09:41
CFX 11.0 includes the SST Curvature Correction and SST Reattachment Modification as beta features. Can anyone give detailed information on what these options are and how they work ? Or alternatively does anyone know where I can learn more on this subject (published paper / book) ?
Also, how can I use these options in PRE ? Shouldn't they appear in the Expert Parameters section after I enable beta features ?
Thanks, your help is always appreciated !
Felix
Andreas Jeromin September 18, 2007 09:36
Re: Curvature Correction & Reattachment Mod.
Hi Felix,
as far as the SST Curvature Correction is concerned I can tell from my own experience that this beta feature is not really implemented yet. I had only a vanishing influence on my test case with the CFX SSTCC activated or deactivated.
In a first test I found that the SST curvature correction proposed by Hellsten (AIAA-98-2554) gave much better results. But it also lead to higher residuals.
When you find out anything else please let me know.
Take care, Andreas
PCFD July 14, 2010 07:51
Hi Jeromin,
with which code did you test the cc-model proposed by Hellsten? It wasn't CFX, right?
Are you using the CC-model in version 12.1, CFX? HAve you varied the CScale-coefficient. Would be interesting to know if that impacts your flow as well. It had quite a big influence on my results - but my experience is limited to version 12.0!!! I will analyze it now in 12.1.
Regards.
stumpy July 14, 2010 08:53
Curvature Correction would only make a difference for strongly swirling flows. In my experience SST + CC gave results similar to a Reynolds Stress model, but without the added expense and with the wall treatment benefits that come with SST. The option appears in Pre on the Domain > Fluid Models panel, under Advanced Control below where you pick your turbulence model (not sure if it's there in 11.0 though). I haven't used the reattachment modification before.
ourdean December 18, 2010 16:28
Hi everyone, I was wondering if anyone had the source code for the curvature correction which i can eyeball and implement, I would really appreciate this please. Could you send/forward to ourdean@gmail.com
Cheers
ghorrocks December 19, 2010 17:04
The source code is not available.
