September 11, 2007, 10:46 |
FSI-time dependent load in cfx10.0
hello, i am working on a fsi simulation in cfx10.0.load is a pressure like "sin 5t".(t is time) but cfx in post processing doesn't accept t.how can i apply this load?should i write a fortran program?can anyone guide me? thanks.
September 12, 2007, 05:12 |
Re: FSI-time dependent load in cfx10.0
How can you define loads in CFX-POST? In order to define load or a boundary condition (B.C) you have to go either to ANSYS or CFX-PRE. If it is load on the structure you can edit your ANSYS input like following under /SOLU or /PREP7:
************ nsel,s,..... !!with nsel select you nodes where you want to apply time-dependent load *dim, press,table,100,1 !define a variable array e.g. press of length 100 delt=1e-4 !define size of time-step FREQ=10 !define freqency e.g. 10 Hz pi = 4*atan(1) ! define your Pi or pi = 3.14157 omega = 2*pi*FREQ p_max = 10 ! amplitude of the load *do,tt,0,100,1 press(tt,0)=tt*delt press(tt,1)=p_max*sin(omega*tt*delt) *enddo SF,all,PRES,%press% ! apply pressure load vector on selected nodes ********* If you want to apply a B.C on the fluid side, this can be done in CFX-PRE. In CFX-PRE a time-dependent B.C can be set by CEL which is quite easy using variable "t". Refer to CFX manuals for this. |
September 15, 2007, 10:28 |
as you wrote i could apply a time dependent b.c in cfx-pre with no error.("sin t" as a mesh displacement in y direction).but when i want to obtain a solution in cfx-solver(start run) an error massage displays that "t is not an angle"! how can i solve this problem? thanks, s.ghassemi
September 16, 2007, 03:28 |
ofcourse "t" is not an angle.
Here is an example: pi = 4*atan(1) freq = 100 [s^-1] theta = 2 * pi * freq * t disp = 0.01 [m] sin(theta) this should work. |
Superlinear speedup in OpenFOAM 13 | msrinath80 | OpenFOAM Running, Solving & CFD | 18 | March 3, 2015 05:36 |
How to write k and epsilon before the abnormal end | xiuying | OpenFOAM Running, Solving & CFD | 8 | August 27, 2013 15:33 |
FSI time | YY | CFX | 0 | April 25, 2008 12:38 |
Could anybody help me see this error and give help | liugx212 | OpenFOAM Running, Solving & CFD | 3 | January 4, 2006 18:07 |
Repeating same time steps (FSI). | cjtune | Siemens | 0 | February 19, 2003 23:05 |
