Can Mesh in initial guess be different that actual
Old   September 18, 2007, 14:33
Default Can Mesh in initial guess be different that actual
Kushagra Mittal
From document 'Initial Condition Modelling: Initialisation Parameters' (ANSYS CFX-Solver, Release 10.0 : Modelling page 95 ), it seems that mesh should be exactly same if initial condition is taken from some result file.
On the other hand, in Tutotrial 2 (Static Mixer with Refined mesh), we select the option 'Interpolate Initial Values onto Def File Mesh' while running the simulation in solver manager.' Meshes in initial solution result file and new simulation file are not same.
I am confused with above two stories.
Kindly suggest where I am misunderstanding...
Many thank in advance,
Regards, Kush.
Old   September 18, 2007, 14:54
Default Re: Can Mesh in initial guess be different that ac
CycLone
You can do either.
If you simply pick a results file to initialize from, the solver will use the physics definition from your .def file and the mesh and results from your .res file.
If you do the same and turn on the "interpolate initial guess" option, the results in the .res file will be interpolated onto the mesh of the .def file.
If your mesh is different than the mesh in the results file, you must turn on the interpolate option or else you'll end up using the old mesh, rather than your new one.
The old interpolation routine was very slow, so you generally wanted to avoid interpolating where possible. It was re-written in version 11 and is extremely fast now, so I would recommend using the interpolation option virtual every time.
-CycLone
Old   September 18, 2007, 15:12
Kushagra Mittal
Thanks a lot !!!!!!!!!!!!!!!!! It makes picture very clear. I am having CFX-11 as well. Thanks once again.
Cheers, Kush.
problem with Min/max rho tH3f0rC3 OpenFOAM 8 July 31, 2019 09:48
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 06:20
ForcesCoeffs ronaldo OpenFOAM 4 September 14, 2009 07:11
Problems with simulating TurbFOAM barath.ezhilan OpenFOAM 13 July 16, 2009 05:55
Modeling in micron scale using icoFoam m9819348 OpenFOAM Running, Solving & CFD 7 October 27, 2007 00:36
