-   -   Problem on Parallel Run Setup (http://www.cfd-online.com/Forums/cfx/24574-problem-parallel-run-setup.html)
Hamidur Rahman September 23, 2007 17:11
Hi Guys, Could any one help out of following problem? I am having problem with the parallel setup. I followed the instruction given in the manual.
I changed the hosts.ccl file as
# ANSYS CFX Host Definition File # # Automatically created # by C:\Program Files\Ansys Inc\v110\CFX\bin\perllib\cfx5parhosts.pl # at Fri Sep 21 14:47:26 2007.
EXECUTION CONTROL: PARALLEL HOST LIBRARY: HOST DEFINITION: STEAMSHIP
Installation Root = C:\Program Files\Ansys Inc\v110\CFX
Host Architecture String = intel_xeon64.sse2_winnt5.1 END # HOST DEFINITION steamship HOST DEFINITION: SLAVE
Remote Host Name = CAB
Installation Root = C:\Program Files\Ansys Inc\v110\CFX END END # PARALLEL HOST LIBRARY END # EXECUTION CONTROL
But when I run my case it found this warning.
Warning! | rsh connection to host CAB produces the following output before |the output of the command: | | Terminal readThe handle is invalid. | | This may cause problems spawning parallel slaves, especially on | | Windows. Warning! | | rsh connection to host CAB produces the following output after the | | output of the command: | | : | It could indicate that an rshd service from a different vendor is | | running, which may not provide the necessary functionality. This | | may cause problems spawning parallel slaves. | An error has occurred in cfx5solve: | | Unable to add host CAB to the PVM environment: | | 80000
