September 25, 2007, 06:18 |
*** INSUFFICIENT MEMORY ALLOCATED *** ??????
Hi there i´m doing a two-domain simulation with ggi, the mesh is very simple (about 5k nodes!!), i´m monitoring the RAM, during the solving i have about (+600mb physical free) but in the first interation there´s an error about :
Action required : Increase the real stack memory size. | | If the situation persists please contact the CFX Customer Helpline | | giving the following details:- | | Requested space: 10992 words | | Current allocated space: 6981171 words | | Current used space: 6969795 words | | Current free space: 11376 words | | Number of free areas: 2 !!!!!????? help please... Thanks (PS: sorry about my english ) |
September 25, 2007, 20:52 |
Re: *** INSUFFICIENT MEMORY ALLOCATED *** ??????
According to the error message, you need to increase the real stack memory size. So try increasing the memory allocation factor to 1.2.
September 26, 2007, 05:15 |
I have the same problem as Pedro, so could You explain to me how to increase the memory allocation factor? Thanks
September 26, 2007, 06:05 |
Yes, what is change the memory allocation factor?
September 26, 2007, 08:00 |
I just solve that problem! Before you start the solver click on the advanced (check it) and in two new tabs you will find the memory allocation factor. It is 1.0, probably it is default, and you can change it (I have changed it to 2, and solved my problem)! Good luck
September 26, 2007, 08:28 |
Ok thanks!! Working!
Display Modes | |
INSUFFICIENT MEMORY ALLOCATED | Virag Mishra | CFX | 2 | May 14, 2007 10:02 |
Insufficient Memory Allocated-error | Juan Catelén | CFX | 2 | April 4, 2007 03:57 |
INSUFFICIENT MEMORY ALLOCATED Error for FSI | Cuong | CFX | 2 | November 6, 2006 19:48 |
INSUFFICIENT MEMORY ALLOCATED | Jan | CFX | 2 | July 16, 2003 00:55 |
INSUFFICIENT MEMORY ALLOCATED | xfshi | CFX | 1 | June 19, 2003 18:54 |
