October 7, 2007, 16:39 |
How to find the seperation region?
I am working on a mixing type of T Pipe Junction flow problem. As we know as the flow passes through the branch into the main header, there is seperation and recirculation downstream of the junction. How do I find out about the size of the seperation bubble? I have two options but both give me different results.
1. Do I look at places where the pressure is negative? A longer region 2. Do I look at places where the velocity is negative? A shorter region compared to former. Or am I mixing recirculation with seperation? Does it mean, seperation ends when velocity attains a positive value at the wall boundary. And Recirculation is the region where the pressure is negative? |
October 7, 2007, 18:52 |
Re: How to find the seperation region?
In 3D there is no general definition of a separation (at least none I am aware of). It is problem dependant - sometimes an isosurface with a slight negative velocity against the flow direction is useful, sometimes the wall shear stress can pick it up, at least the separation/reattachment lines. Glenn Horrocks |
October 7, 2007, 23:45 |
Thanks a heap Glenn.
I never realised that creating an isosurface could be so helpful. I was trying to do it the old way, you know by plotting velocity profiles along the length. But this surely is a lot better, making it easier to do it as well as to visualize the flow field! Plenty thanx again Omer |
October 8, 2007, 08:12 |
i think you should look up the distribution of the velocity u gradient y,if it is equal to zero. there is the seperation place.
[snappyHexMesh] Multi Region Meshing | bruce | OpenFOAM Meshing & Mesh Conversion | 12 | July 31, 2013 10:09 |
[Commercial meshers] Using starToFoam | clo | OpenFOAM Meshing & Mesh Conversion | 33 | September 26, 2012 04:04 |
How to find RPM from wind speed in Floworks? | Matco | FloEFD, FloWorks & FloTHERM | 21 | March 22, 2010 15:18 |
A way of creating blocks in ICEM for seal region | Mustafa T | CFX | 1 | August 23, 2005 03:37 |
A way of creating blocks in ICEM for seal region | Mustafa T | CFX | 0 | August 22, 2005 11:21 |
