Mesh motion
Old   September 27, 2007, 07:51
Default Mesh motion
Samuel
Hi people,
I'm wondering if it's possible to set a mesh displacement at an opening (or outlet) boundary with CFX 10 or 11. My problem is to simulate a journal bearing. The shaft is fixed and the bearing is moving according to the applied external load. So I specified the displacement of the mesh on the bearing boundary (wall boundary), and I would like to have a mesh motion as "unspecified" on the side of the geometry, i.e. on the opening boundary.
It doesn't seem to be possible to do that. Someone has some suggestions for it?? Thanks.
Old   September 28, 2007, 16:29
Default Re: Mesh motion
SST
Why don't just specify velocity on the outer surface boundary is there a reason/?
Old   October 1, 2007, 10:48
Samuel
The outer boundary is a wall with no velocity. Neverthesless I specified a mesh displacement at this boundary because I want to keep my shaft centered. But the problem is at the opening boundary.
how to set periodic boundary conditions Ganesh FLUENT 15 November 18, 2020 06:09
Mesh motion with Translation & Rotation Doginal CFX 2 January 12, 2014 06:21
3D Hybrid Mesh Errors DarrenC ANSYS Meshing & Geometry 11 August 5, 2013 06:42
Dynamic moving mesh Pei-Ying Hsieh (Hsieh) OpenFOAM Running, Solving & CFD 64 June 7, 2012 10:04
Mesh motion on inlet (2-way FSI) Lance CFX 2 August 13, 2009 05:31
