Home > Forums > CFX
cfx5interp problem
Old   October 10, 2007, 02:52
Default cfx5interp problem
Ramesh
Hi
I am able to interpolate using cfx5interp command from a result file to def file when there is change in mesh but domain dimensions are same.
But now have extruded the domain in z-direction. But kept the kept the mesh count constant. When I interpolate now its giving me an error and I am unable to interpolate.
Input your suggestions on how to interpolate this.
Thanks Ramesh
Old   October 10, 2007, 11:05
Default Re: cfx5interp problem
CycLone
Hi Ramesh,
If the mesh remains the same (i.e. you are only moving the nodes), you can enable an environment variable to force the interpolator to ignore the locations and simply interpolate the values. The environment variable is "CFX_INTERP_NOCRDVX_CHECK". Make sure you remove it when you're done or it will mess up other runs.
-CycLone
Thread Tools
Trackbacks are On
UDF compiling problem Wouter Fluent UDF and Scheme Programming 6 June 6, 2012 04:43
Gambit - meshing over airfoil wrapping (?) problem JFDC FLUENT 1 July 11, 2011 05:59
natural convection problem for a CHT problem Se-Hee CFX 2 June 10, 2007 06:29
Adiabatic and Rotating wall (Convection problem) ParodDav CFX 5 April 29, 2007 19:13
Is this problem well posed? Thomas P. Abraham Main CFD Forum 5 September 8, 1999 14:52
