October 12, 2007, 01:40 |
how to mesh the small inlet?
I want to simulate some big vessel aerated by a gas ring sparger. the sparger is a pipe with many small holes which is bended to a ring)
the gas inlet (samll holes) is very small, how can i mesh them? |
October 12, 2007, 07:29 |
Re: how to mesh the small inlet?
If you are using ICEM, best solution will be to create seperate bodies, for the region where you want fine mesh (around inlet) & rest of your domain. Define different mesh sizes for these bodies & surfaces attached to them. But, before this have a careful look at your geometry & see if you can simplify it. I mean, have common inlet instead of many small holes. This may not be always possible. So, just have a look.
Best luck, Chirag |
Display Modes | |
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 06:20 |
Converting Starccm+ mesh | Ladnam | OpenFOAM | 0 | September 14, 2011 06:30 |
engrid -> save as .stl with boundarie codes | Zymon | enGrid | 31 | August 29, 2011 13:40 |
How to control Minximum mesh space? | hung | FLUENT | 7 | April 18, 2005 09:38 |
unstructured vs. structured grids | Frank Muldoon | Main CFD Forum | 1 | January 5, 1999 10:09 |
