Home > Forums > CFX
Editing current run or definition file.
Old   October 12, 2007, 16:16
Default Editing current run or definition file.
KM
Few more doubts !!!!
1) In CFX-solver>Tools>'Edit Definition File' or 'Edit run in progress' , I see that we can only edit the parameters which appear in GREEN color. The 'Simulation type' ('steady or unsteady state') and 'turbulence models' do not appear in GREEN color and hence can not be changed.
Is there any way out to do that ???? I got an impression from one fluent user that it is possible to do in Fluent.
Thanks a lot for the information,
Best Regards, KM.
Old   October 12, 2007, 17:43
Default Re: Editing current run or definition file.
opaque
Dear KM,
In CFX, only certain parameters can be changed at run time using the CFX-Solver Manager editor. For those that do not appear in GREEN, you must create a new definition file in CFX-Pre and restart your simulation using your previous results.
Opaque
Old   October 12, 2007, 17:46
KM
Thanks a ton !!!! It helps. Regards, KM.
Thread Tools
Trackbacks are On
swak4foam building problem GGerber OpenFOAM Installation 54 April 24, 2015 16:02
GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh gschaider OpenFOAM 300 October 29, 2014 19:00
Paraview command not found hardy OpenFOAM Paraview & paraFoam 7 September 18, 2008 04:59
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 17:51
error while compiling the USER Sub routine CFD user CFX 3 November 25, 2002 16:16
