Casson issue
Old   October 17, 2007, 01:46
Default Casson issue
CC
Hi all,
I'm using CFX11, simulating a 3D bloodflow through a stenosed artery using the Casson model. When I got my results, the wall shear stress for the casson model is around 300000pa at the stenosis compared to 120pa when using the Powerlaw model. What could of gone wrong?
Here is my casson model: LIBRARY: MATERIAL: Casson
Material Group = User
Object Origin = User
Option = Pure Substance
PROPERTIES:
Option = General Material
DYNAMIC VISCOSITY:
Maximum Shear Strain Rate = 100 [s^-1]
Minimum Shear Strain Rate = 0.001 [s^-1]
Option = Casson
Viscosity Consistency = 10 [kg m^-1 s^-1.0]
Yield Stress = 100 [Pa]
END
EQUATION OF STATE:
Density = 1050 [kg m^-3]
Molar Mass = 1e-10 [kg kmol^-1]
Option = Value
END
END END END
Thanks All, CC.
Old   October 17, 2007, 07:58
Default Re: Casson issue
opaque
Dear CC,
The solution does not have to be the same; however, the difference is alarming at first glance.
Here are a few questions:
1 - What power law index did you use for the "powerlaw model"? The value must be consistent with the Casson model (n=1?)
2 - Have you tried running the Casson model w/o yield stress? That will rule out any problem with the yield component..
3 - Did you run the built-in power law (Ostwald de Waele) model, or your own CEL expressions?
If you think that something is still wrong, please contact ANSYS CFX help desk and request someone look into the problem.
Opaque
Old   October 17, 2007, 20:29
CC
Hi Opaque,
I used CEL for my power-law model. Here is my CEL expression:
Mu: Mu0*(min(UpperS,max(sstrnr,LowerS))^(n-1))
where n is 0.6, Mu0 is 0.035 and the upper and lower bounds are the same as I specified in my casson CCL. How would I adapt my CEL expression for Power-Law into command editor for Casson model?
Thanks, CC.
Issue installation OpenFOAM - libopen-rte.so.0 Voyage_gui OpenFOAM 1 August 12, 2011 03:46
Meshing related issue in Flow EFD appu FloEFD, FloWorks & FloTHERM 1 May 22, 2011 08:27
How to use Casson model in CFX zhou CFX 0 October 11, 2005 05:34
STAR-CD Dynamics issue 16 CD adapco Group Marketing Siemens 0 November 30, 2001 10:25
Issue 4 of adapco-online Sreenadh Jonnavithula Main CFD Forum 8 January 5, 2001 13:40
