Elastic solid in CFX 10.0
Old   September 25, 2007, 13:36
Default Elastic solid in CFX 10.0
siavash ghassemi
hello,i want to define a solid material with elastic property in CFX10.0.but there is not any icons for this in materials tab.how can i apply E? thanks
Old   October 15, 2007, 02:26
Default Re: Elastic solid in CFX 10.0
Chirag
To see solid material behavior in terms of physical displacements / stresses, you need some FEA software like ANSYS. CFX can't do that. Again, to solve a problem that includes both, fluid phenomenon & solid physical response to it and vise versa, then you got to go for FSI (CFX & ANSYS-FEA combined). Read about FSI in CFX help. Contact your local ANSYS-CFX support for more detail on it.
Best luck, Chirag
Old   October 17, 2007, 06:48
siavash ghassemi
as you wrote i find it in cfx help,but i have a new question.the pressure load transfers from cfx to simulation in a specified time(eg:t=1.5 s).can i transfer the pressure load in total time and make an animation in simulation? thanks for your answer.
Old   October 18, 2007, 03:54
Chirag
I have never tried FSI myself. So, about your first question on 'load transfer at a particular time' I will not comment anything. Animation - ofcourse you can have animation in CFX & ANSYS both. There are different ways for the same. Check them out in respective Help files.
Best luck,
Chirag
question about immersed solid in CFX 12.0 Anny CFX 11 October 4, 2016 04:22
modeling particle transport in ansys cfx 10.0 siavash CFX 9 November 23, 2010 21:21
PhD using CFX Rui CFX 9 May 28, 2007 05:59
Problem on mesh import to Ansys CFX 10.0 Stephen Lau CFX 1 April 18, 2007 03:02
CFX 4.4 installation problem Pandu Sattvika CFX 1 December 1, 2001 04:07
