October 22, 2007, 12:50 |
Using script file in ICEM CFD
Hi
I have a number of similar models which I want to simulate. I guess, by making use of script file writing I can just block one model and replay the file so that I can block rest of the models automatically. But while doing so, it is showing some error. To replay a script file, does it need to meet any special requirement? |
October 22, 2007, 17:45 |
Re: Using script file in ICEM CFD
Hello, the tetin files should have consistency. The names of the entities like points, curves and surfaces should be exactly same between the tetin files. What exactly is the error shown?
Regards Anantha |
[swak4Foam] swak4foam building problem | GGerber | OpenFOAM Community Contributions | 54 | April 24, 2015 16:02 |
[OpenFOAM] Paraview command not found | hardy | ParaView | 7 | September 18, 2008 04:59 |
Compiling OpenFOAM13 on AMD64 with Redhat Enterprise | mbeaudoin | OpenFOAM Installation | 20 | June 17, 2008 06:43 |
DecomposePar links against liblamso0 with OpenMPI | jens_klostermann | OpenFOAM Bugs | 11 | June 28, 2007 17:51 |
error while compiling the USER Sub routine | CFD user | CFX | 3 | November 25, 2002 15:16 |
