Home > Forums > CFX
Realizing algorithm in CFX
Old   October 29, 2007, 04:06
Default Realizing algorithm in CFX
Bloshchitsyn Vladimir
Hello! I want realize algorithm for computing source term ( x, y, z) in CYLINDER region (subdomain):
1) Calculate inegral for specified Z section ( to determine ~ E electric field by current ) ... Intergal will be dounle summ of Temperature ( Function of temperature ) by x and y
2) Calculate source term using resuls of step 1)
AFAIK, for this procedure I should use functions like described there http://www.cfd-online.com/Forum/cfx_...cgi?read=21401
<QUOTE>---------------------- 1 - USER_CALC_INFO to determine the LOCALE and ENTITY for step 3
2 - USER_GETVAR to get the "vector variable"
3 - USER_GET_MESHDATA to get the Normal Area Vector. Here you must use WHAT='Normal Area Vector", WHERE=Faces|Integration Points depending if ENTITY=CENTRE|IP
4 - USER_GET_MESHDATA to get the Volume Sector using WHAT='Volume', and WHERE='Sectors'
Then, pass the stack pointers into a local routine that will compute something like (be careful with indexing and array shapes).
DO I = 1, N
VAR(I) = (VECTOR(1,I)*AREA(1,I) +VECTOR(2,I)*AREA(2,I) +VECTOR(3,I)*AREA(3,I)) / VOLSEC(I) ENDDO
<QUOTE>-----------------------------------------------
Can you present, this algorithm more detailed?
Thread Tools
Trackbacks are On
heat generation in CFX Ema CFX 4 August 7, 2009 05:39
Electronics Enclosure Analysis with CFX Simulation Engineer CFX 1 April 22, 2009 11:08
CFX 10's solutions differ from CFX 5.7's Atit Koonsrisuk CFX 4 July 26, 2006 11:59
Modified Equation for CFX algorithm Craig Johansen CFX 0 August 27, 2004 23:02
CFX 4.4 installation problem Pandu Sattvika CFX 1 December 1, 2001 05:07
