-   -   negative solid volume error (http://www.cfd-online.com/Forums/cfx/24748-negative-solid-volume-error.html)
Luis October 29, 2007 08:19
I am trying to mesh a 3D solid with CFX v11, but I get the following error message:
"The calculated volume of this solid is negative. A volume mesh cannot be generated. This can occur if you have tried to volume mesh a surface body"
This is strange because when I verify the geometry I get no error messages and when I generate the surface mesh neither. Also, this same model was reporting no errors in CFX v10. Does anybody how can I fis this problem?
thanks,
Luis
Glenn Horrocks October 29, 2007 18:36
Re: negative solid volume error
Are you meshing in Workbench?
Luis October 30, 2007 04:23
Yes, I am meshing in Workbench with CFX-Mesh.
Glenn Horrocks October 30, 2007 19:04
In that case the problem is almost always due to either using too large an element to capture a small geometry feature or a poor geometry model which overlaps itself.
