negative solid volume error
Old   October 29, 2007, 07:19
Default negative solid volume error
Luis
I am trying to mesh a 3D solid with CFX v11, but I get the following error message:
"The calculated volume of this solid is negative. A volume mesh cannot be generated. This can occur if you have tried to volume mesh a surface body"
This is strange because when I verify the geometry I get no error messages and when I generate the surface mesh neither. Also, this same model was reporting no errors in CFX v10. Does anybody how can I fis this problem?
thanks,
Luis
Old   October 29, 2007, 17:36
Default Re: negative solid volume error
Are you meshing in Workbench?
Old   October 30, 2007, 03:23
Luis
Yes, I am meshing in Workbench with CFX-Mesh.
Old   October 30, 2007, 18:04
In that case the problem is almost always due to either using too large an element to capture a small geometry feature or a poor geometry model which overlaps itself.
polynomial thermophysical properties II sebastian OpenFOAM Running, Solving & CFD 54 November 21, 2019 07:12
How to install CGNS under windows xp? lzgwhy Main CFD Forum 1 January 11, 2011 18:44
attach/detach (valve opening/closing) phsieh2005 OpenFOAM Running, Solving & CFD 2 March 21, 2009 05:18
OpenFOAM on MinGW crosscompiler hosted on Linux allenzhao OpenFOAM Installation 127 January 30, 2009 19:08
user defined function cfduser CFX 0 April 29, 2006 10:58
