Maximum of two different results files
Old   October 30, 2007, 05:33
Default Maximum of two different results files
Nicki Parker
I'm doing some external wind analysis and wish to compare velocities for different wind directions. Does anyone know if there is any way I can plot a contour showing the maximum of, say, two different wind directions? At the moment I am looking at each one, then drawing rough outline shapes for the highest velocities using a drawing package, but I'm wondering if CFX has a better way of doing this.
Thanks in advance,
Nicki
Old   October 30, 2007, 18:00
Default Re: Maximum of two different results files
I am not sure what you are trying to do. Can't you do an isosurface and compare images between two different results files? Also CFX11 added support for multiple results files so you can have both results files displayed to more clearly show the differences.
Old   October 30, 2007, 18:36
CycLone
The current results comparison capability only allows qualitative comparison of results. That said, you can do what you desire by creatively using the variable "copy" option. Do the following:
1. Load your first results file. 2. Create a new variable called 'Old Velocity' (or a vector variable of each component) as a copy of the Velocity variable. 3. Load your second results file. 4. Create a new variable called Max Velocity and set it equal to max(Velocity, Old Velocity).
Now just create a contour plot of Max Velocity.
When you create a variable copy, Post keeps the variable field in memory. As long as the second results file has the same mesh, you're variable will remain. You can get creative with this and do lots of cool things...
-CycLone
Old   October 31, 2007, 05:22
Nicki Parker
Thanks for that. Unfortunately, I've just tried this, and it seems to only be plotting the first set of velocity results, rather than a combination of the two. Any ideas as to what I'm doing wrong?
Nicki
Old   November 1, 2007, 07:29
Nicki Parker
I have now managed to do this, but have now come across another problem. In total, I wish to compare 8 sets of results. I formulate all the maximum expressions, however, a pop-up window comes up saying I have insufficient memory when I try to plot the final contour. I have tried loading results one by one and then plotting the maximum as I go along, but infuriatingly, I can only get to the 7th set of results. Do you know of any way to get around this? I've tried exporting the results on the user surface, but when I try to import them, it says that it can't recognise the file type.
Any advice would be greatly appreciated.
Thanks,
Nicki
Old   November 2, 2007, 15:55
CycLone
You can create a variable copy of the maximum each time, rather than trying to load all 8 velocity fields into memory at once. If you sequentially calculate the maximum feild, you will end up with the same result.
-CycLone
UDF issue MASOUD Fluent UDF and Scheme Programming 14 December 6, 2012 13:39
Can I modify runTimeWrite() to output results into one folder? ovie OpenFOAM 12 January 22, 2011 19:52
Results file naming convention amtri OpenFOAM 8 September 7, 2010 08:54
OF 1.6 | Ubuntu 9.10 (64bit) | GLIBCXX_3.4.11 not found piprus OpenFOAM Installation 22 February 25, 2010 13:43
Problems with result files Kasper CFX 5 December 14, 2006 02:41
