FSI simulation thermal analysis
Old   November 2, 2007, 01:45
Default FSI simulation thermal analysis
Michelle
I'm simulating a fluid flow in an stainless pipe. I want to ask if I can use two way FSI to compute for the changes in temperature in both the pipe and fluid. I saw a demo about one way FSI where the wall temperature of the fluid was solved first and then loaded it as initial condition of the inside wall of the pipe. However, I want to know the effect of this heat loss to the temperature of the fluid. Do you have any suggestion on how to do it guys? Thanks!
Much appreciated, Michelle
Old   November 3, 2007, 06:56
Default Re: FSI simulation thermal analysis
johnny
You can do a CHT problem in CFX - you wouldn't need a two way FSI if all you were trying to solve was heat conduction in the solid domain. If you need the thermal stresses in the solid, or the deformation of the solid is significant, then a two way FSI is necessary.
Old   November 3, 2007, 09:15
Michelle
Thanks a lot johnny!! I will try advise. Thanks again!
FFT for Post Simulation Analysis faisal_durr CFX 12 March 13, 2012 03:35
thermal analysis raffap Siemens 7 May 23, 2011 02:08
wrong values in thermal analysis Trofrensis STAR-CCM+ 0 December 7, 2009 05:41
Transient Thermal Analysis with FSI Abduri CFX 2 March 27, 2009 02:47
FSI TWO-WAY SIMULATION Smagmon CFX 1 March 6, 2009 13:24
