Continuity equation
Old   November 11, 2007, 23:34
Default Continuity equation
selim
Hi all
I have a problem in satisfying the continuity locally. I took values for velocities (u and v) from CFX and using gradients (in matlab I am sure this is right , I tested with simple cases) then look at the delta U divided by delta X + delta V divided by delta Y) but results seems not to be 0 \
Thanks
Old   November 20, 2007, 11:04
Default Re: Continuity equation
Jim
I'm not going to check you maths, but assuming you're working it out right, then the obvious answer is that your solution is not sufficiently converged. Try a little experiment. Check out the values you get from the same simulation with varying levels of convergence. Maybe set the RMS residual convergence target to 1e-1, 1e-2, 1e-3, 1e-4 etc etc, and see by how much you calculation is out for the different convergence levels.
You haven't mentioned whether there is anything else going on like sources, BCs or whatever that might effect the local continuity.
How to write k and epsilon before the abnormal end xiuying OpenFOAM Running, Solving & CFD 8 August 27, 2013 15:33
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 bookie56 OpenFOAM Installation 8 August 13, 2011 04:03
IcoFoam parallel woes msrinath80 OpenFOAM Running, Solving & CFD 9 July 22, 2007 02:58
continuity equation Rafal Main CFD Forum 4 November 29, 2006 09:27
Could anybody help me see this error and give help liugx212 OpenFOAM Running, Solving & CFD 3 January 4, 2006 18:07
