Surface integral calculation by undefined area |
November 18, 2007, 22:19 |
Hello!
I need calculate E(z,t)=∫FUNC(x,y,z,t)*dx*dy expression in specified domain... I want realize next algorithm: 1) Searching elements in layer z±δ 2) Select integrations point and area vectors by USER_GET_MESHDATA function with option "normal area vector" 3)Calculate function FUNC in nodes by getting fields in nodes (NLOCs) by USER_GETVAR function 4)Calculate expression âˆ'J([EJ_AIP1+ EJ_AIP2+… EJ_AIPN], [0 0 1] ) * FUNC Can you give me some advices about this algorithm? P.S. Do I get area of faces or sectors At 2) step?... In manual: "normal area vectors at integration points" Thanks!!! |
[ICEM] Problems with coedge curves and surfaces | tommymoose | ANSYS Meshing & Geometry | 6 | December 1, 2020 11:12 |
LiencubiclowRemodel | nzy102 | OpenFOAM Bugs | 14 | January 10, 2012 08:53 |
[ICEM] Automatic mesh generation script surface intersection problem | stuart23 | ANSYS Meshing & Geometry | 0 | May 13, 2011 01:10 |
OpenFoam-1.7.x on Suse 11.2 (64bit) does not compile | val46 | OpenFOAM Installation | 4 | August 27, 2010 03:43 |
CFX4.3 -build analysis form | Chie Min | CFX | 5 | July 12, 2001 23:19 |
