Tri Tolerance in ICEM Hexa
Old   November 21, 2007, 02:39
Default Tri Tolerance in ICEM Hexa
Mohammad Faridul Alam
can anybody tell me what is tri tolerance in ICEM HEXA?
Old   November 21, 2007, 11:55
Default Re: Tri Tolerance in ICEM Hexa
myron
Tri Tolerance is a measure of how well the geometry (tetin file) is tessellated when read into the Mesh Editor. Typically the default value is good enough. However, if you're using very fine near-wall spacing, sometimes you need to reduce this. Change the value, then save and re-load the tetin file to make the change in active memory. This takes more memory to represent the geometry, but it will be truer to the actual shape.
ICEM hexa mesh built with v10 deformed in v11 (degenerated edges) cfxicem ANSYS Meshing & Geometry 1 October 14, 2009 16:06
ICEM HEXA - Where to start? flattie CFX 3 May 26, 2009 10:12
ICEM hexa mesh 2d car example icem student Main CFD Forum 0 May 11, 2008 20:17
Hexa smoothing (ICEM CFD 10.0) CFDworker CFX 3 November 2, 2005 11:23
ICEM HEXA Grid Manish Phoenics 0 March 12, 2005 06:07
