-   -   Area-averaged Nusselt number (http://www.cfd-online.com/Forums/cfx/24871-area-averaged-nusselt-number.html)
Surfinggirl December 2, 2007 13:37
Hello together!
I'm investigating a jet impingement cooling arrangement using cfx11.0 and I want to calculate the area averaged Nusselt number of different areas of the target surface. Now my question; how can I divide the target surface (which is one domain in cfx till now) in several areas using cfx post. And how can I calculate the area averaged Nusselt number of these surfaces?
Hope you can help me! Thank you
Glenn Horrocks December 2, 2007 17:20
Re: Area-averaged Nusselt number
The best way is to define them as separate regions in meshing then it is easy to get the results in post-processing. If the target surface has different facets you can still get CFX-post to calculate based on the facets. If you want to sub-divide a larger surface in CFX-Post you can use the bounds option or a user surface with method "from contour" and make the defining contour X/Y/Z functions to define the region you want. It is fiddley but it can be done.
