Negative Volume Error
i am doin an analysis of different aerofoils but am not able to procedd coz watever meshing i do i keep gettin the negative element error. i am using icem cfd wat correction should i do to rectify this?? help Plz!!
Srinivethan |
Re: Negative Volume Error
This error is common in moving mesh - I assume you do not have any moving mesh. If you have a static mesh then you either have a very poor mesh where some elements have been turned inside out (sometimes too much smoothing can do this) or the normal vectors are wrong (this is easy fixed in ICEM). Glenn Horrocks |
thanks but my mesh quality is fine i checked it out. and i am doin a 2d analysis as in when i am exporting from icem i am giving the z scale as 0. so basically i get a 2d structure in cfx will that be a problem???
No that will not work and that is where the error is coming from. You need to have a finite thickness in the z direction. Also read the FAQ: http://www.cfd-online.com/Wiki/Ansys...tion_in_CFX.3F Glenn Horrocks |
