Home > Forums > CFX
additional variable- "sum" function
Old   December 11, 2007, 11:56
Default additional variable- "sum" function
Mike
Hi Everyone, I am using CFX 11 package. I want to inject dye only for 2 seconds from domain inlet(already predicted flow field, I turned off the fluid solver from expert parameters, so it is just transport equation of additional variable)and get total concentration curve at the outlet.
Here is the two seconds injection of dye. "DyeMassFlow = (step ((2[s]-t)/ (1[s])))*(1[kg])/(2[s])"
Here is the additional variable. "ADDITIONAL VARIABLE: Dye
Option = Definition
Tensor Type = SCALAR
Units = [kg/s]
Variable Type = Volumetric"
And here is the total concentration at the outlet
"TotalDye = sum(Dye)@Outlet" The problem is I am injecting 1 kg dye as a total, however the total I am geting at the outlet is far more than the value I am injecting.
Can anyone tell me what I am doing wrong? Thanks a lot Regards, Mike
Old   December 11, 2007, 13:37
Default Re: additional variable- "sum" function
CycLone
Hi Mike,
Your scalar units shoud be [kg/m^3] for volumetric or [kg/kg] for specific. Also, the step() function will return 0.5 when the operand is zero, so you may want to write it as (step ((1.9999[s]-t)/ (1[s])))*(1[kg])/(2[s]) so the value at 2 [s] is exactly zero.
If you apply this at the inlet, the dye mass flow rate will be a function of the inlet flow rate (because the flow is transporting it). If you solve it as a specific variable [kg/kg], the dye flow rate will be equal to the dye mass fraction (it's value) times the mass flow rate through the inlet. If you set it up as a volumetric AV, it will be the inlet volume flow rate times the volume fraction (i.e. (mass flow/density)*volume fraction).
Alternatively, you could specify the dye as a source injection at the inlet, as opposed to a value. In this case you would use the function as you have it now and the local concentration will depend on the flow rate.
-CycLone
Old   December 11, 2007, 16:19
Mike
Thank you so much,CycLone.
Old   December 11, 2007, 17:25
Also the "sum" function is not the correct way of getting the amount of AV in a volume or across an interface. The sum function just does a simple sum at all nodes. You should use one of the integrating functions, such as volumeInt() or areaInt(). You might also want to use a mass flow function massflowInt() which integrates against mass flow across an interface rather than the area integral function.
Regards, Glenn
Old   December 12, 2007, 11:22
Mike
Thanks a lot, Glenn.
Thread Tools
Trackbacks are On
Compile problem ivanyao OpenFOAM Running, Solving & CFD 1 October 12, 2012 09:31
channelFoam for a 3D pipe AlmostSurelyRob OpenFOAM 3 June 24, 2011 13:06
OpenFOAM static build on Cray XT5 asaijo OpenFOAM Installation 9 April 6, 2011 12:21
latest OpenFOAM-1.6.x from git failed to compile phsieh2005 OpenFOAM Bugs 25 February 9, 2010 05:37
Version 15 on Mac OS X gschaider OpenFOAM Installation 120 December 2, 2009 11:23
