ERROR IN OPENING CFX POST
Old   December 18, 2007, 08:08
Default ERROR IN OPENING CFX POST
VISHNU
Hai,
I'm working on a model in Ansys Cfx.Form last two days i'm not able to open the results in POST.I'm getting an error as
ERROR
Error reading file 'D:\Model..\Object_003.res':
Error reading dataset G/COMMANDS
I have nearly 35GB of free space in working drive. Can anyone please help me in this.
Old   December 19, 2007, 02:50
Default Re: ERROR IN OPENING CFX POST
Hong Xiao
My partner and I are trapped in this cage too.It always happened in the post-processing of unteady flow.Would you please describe it more detailly?
Old   December 19, 2007, 03:30
VISHNU
hai,
Thanks for your responce.
I'm working with a model containing 25laks elements. Previously i used to load results easily and normally.But since 3 days i,m getting this error.Even i'm not able to open ".res"files which i previously used to open.I have freespace of about 35GB,5GB in D & C drives respectively.This error occur wheni try to post process the result.
Old   December 19, 2007, 03:33
VISHNU
my model is under steady state condition.
Old   December 19, 2007, 08:23
Hong Xiao
25laks element means? I think freespace is not the key. what about your CPU , memory and graphic card ?
Old   December 19, 2007, 19:17
Usman
I think he meant 2.5 million elements by "25 laks". I hope it was not a swear word! Anyway i ran my simulation for three days and now i am receiving same error message. I also have plenty of space in my hard disk. Please let me know about it if you figure out how to open up the file in post-processor.
Regards Usman
Old   January 7, 2008, 03:21
maddy
Is your problem run pproperly? if yes then check its output file then go next
maddy
CFX post legend modification mactech001 CFX 3 December 25, 2011 22:12
CFX Post export problem jeff_F CFX 0 August 17, 2009 21:25
chart for transiente simulation - CFX Post rogbrito CFX 0 June 22, 2009 12:12
Chart Generation in CFX Post Vadim Baines-Jones CFX 2 August 28, 2007 09:14
icem cfd geometry tin file not opening cfx 10 c mayur CFX 2 July 10, 2007 02:57
