-   -   How to edit point coordinates in ICEM? (http://www.cfd-online.com/Forums/cfx/24949-how-edit-point-coordinates-icem.html)
Alexey December 19, 2007 05:36
I am beginner at CFX and now I study ICEM grid generator. I wonder how I can edit point coordinates in ICEM?
I found that after point creation I can't modify its coordinates. I can delete it and create again with new coordinates but I did not find how to modify coordinates of existing point.
Please, help me.
Alexey.
Christian Andersen December 19, 2007 10:19
Re: How to edit point coordinates in ICEM?
Hi Alexey,
I dont think that feature is available in ICEM, do you know any mesh generator that allows that?
I am also new to ICEM, but I've also tried to edit geometries without deleting them - but it doesn't seem possible.
Please let me know if you figure it out.
Best
Christian
Chirag Jayswal December 20, 2007 02:21
You can not edit any point in ICEM. You need to create new point and also curves & surfaces attached to it if any.
I do not know any meshing software that does it. Dedicated geometry building / modelling software can do this.
Chirag
Alexey December 20, 2007 04:30
Yes, it seems it is impossible.
I found the following possibility: Tab Mesh -> Move Nodes (icon with arrow and two bold spots) Unfortunately this function does not act upon points.
As I know STAR-CD can modify existing points. . . :(
I have many problems with ICEM 11.0. For example, when I try to make blocking initialization (after primitive geometry creation " 4 points and 4 lines) often error occurs:
Error meshing edge 22 14
And instead of white block rectangle two infinity lines appear . . .:(
What is the matter? I don't know. . .
James Date December 21, 2007 08:04
Yeah, it is possible. You can translate, rotate it, copy it or even edit its x,y,z locations if you open the .tin file in a text editor.
Alexey December 21, 2007 11:20
James, thanks a lot! It is really solution of this problem but it looks a perversion . . . :)
Thank you.
myron December 24, 2007 11:31
Yes - Simply go to the Move/Copy Geometry icon. From there you can select points, curves, and/or surfaces. Then you simply enter the translation values (X,Y, and/or Z) and move the point.
