Home > Forums > CFX
ERROR #001100279,Floating point exception:Overflow
Old   January 7, 2008, 09:13
Default ERROR #001100279,Floating point exception:Overflow
sohail ahmed
I am trying to simulate a centrifugal pump stage with transient conditions. In this case, Massflowrate and rotating speed of impeller are changing with time. I have set Total time = 1 hr and Time step= 1 min. Maximum coefficient loops are set to 3.
Unfortunately, I am getting Following error:
ERROR #001100279 has occurred in subroutine ErrAction. | | Message: | | Floating point exception: Overflow
Can anyone help me out plz.
Thanks.
Old   January 7, 2008, 18:14
Default Re: ERROR #001100279,Floating point exception:Over
Your timesteps sound very large for a typical pump. Read the documentation section about Best practices for turbomachinery to give you some pointers.
Old   January 8, 2008, 11:55
sohail ahmed
Dear Glenn Horrocks,
Reducing time step to 1 second eliminate this error. But If I have to simulate transient behavior of my pump for 3 hours, this means total 60 x 60 x 3 = 10,800 time step iterations and with inside coefficient loop iterations, this problem becomes HUGE!. Any suggestion and idea to simulate pump transient behavior in reasonable time?
Old   January 8, 2008, 17:24
Why do you need to run for 3 hours? Surely the pump reaches steady state way before then.
Also, in CFD sometimes you just have to run huge problems. That is why CFD is run on supercomputers.
Old   July 14, 2010, 02:18
M. A.
motahar is on a distinguished road
Hi friends,
I'm simulating a vver-1000 reactor pressure vessel.
When I give pressure change to the interface boundaries, I encounter the same error of overflow.
I'm using the k-e model, and because I'm analyzing the heat transfer in the reactor, I have to use k-e model.
I change the turbulent model to SST and it answered, but can anybody helps me how to solve my problem when using k-e model.
Waiting for your help!
motahar is offline   Reply With Quote
Thread Tools
Trackbacks are On
block-structured mesh for t-junction Robert@cfd ANSYS Meshing & Geometry 20 November 11, 2011 05:59
Problem with UDF compiling for kTkLW model Wantami FLUENT 0 July 18, 2011 05:11
Point flow exception:overflow Jwala CFX 6 January 29, 2009 03:08
Gmsh and samplesurface touf Open Source Meshers: Gmsh, Netgen, CGNS, ... 2 December 10, 2007 03:27
CFX4.3 -build analysis form Chie Min CFX 5 July 12, 2001 23:19
