-   -   error using combination of step function (http://www.cfd-online.com/Forums/cfx/25038-error-using-combination-step-function.html)
xujjun January 15, 2008 07:19
i want to set two bubble in initial condition, someone gave me a suggestion, the combination of step function is used, however,the cfx is terminal because of error,just like this:
i do not know how to do? +--------------------------------------------------------------------+ | | | CFX Command Language for Run | | | +--------------------------------------------------------------------+
LIBRARY:
CEL:
EXPRESSIONS:
DenH = 1000 [kg m^-3]
DownH1 = 0.040 [m]
Pres1 = DenH*g*DownH1
Rbubble1 = 0.001 [m]
UpVFbubble1 = step(((0.0008 [m]^2-(x-0.0015 [m])^2-(z-0.0015 \
[m])^2))/1[m^2])+step(((0.0008 [m]^2-(x-0.0015 [m])^2-(z-0.0025 \
[m])^2))/1[m^2])
UpVFwater1 = 1-UpVFbubble1
dist1 = Rbubble1-sqrt((x-0.0025[m])^2+(z-0.002[m])^2)
END
END
MATERIAL: Air at 25 C
Material Description = Air at 25 C and 1 atm (dry)
Material Group = Air Data, Constant Property Gases
Option = Pure Substance
Thermodynamic State = Gas
PROPERTIES:
Option = General Material
Thermal Expansivity = 0.003356 [K^-1]
ABSORPTION COEFFICIENT:
Absorption Coefficient = 0.01 [m^-1]
Option = Value
END
DYNAMIC VISCOSITY:
Dynamic Viscosity = 1.831E-05 [kg m^-1 s^-1]
Option = Value
END
EQUATION OF STATE:
Density = 1.185 [kg m^-3]
Molar Mass = 28.96 [kg kmol^-1]
Option = Value
END
REFRACTIVE INDEX:
Option = Value
Refractive Index = 1.0 [m m^-1]
END
SCATTERING COEFFICIENT:
Option = Value
Scattering Coefficient = 0.0 [m^-1]
END
SPECIFIC HEAT CAPACITY:
Option = Value
Reference Pressure = 1 [atm]
Reference Specific Enthalpy = 0. [J/kg]
Reference Specific Entropy = 0. [J/kg/K]
Reference Temperature = 25 [C]
Specific Heat Capacity = 1.0044E+03 [J kg^-1 K^-1]
Specific Heat Type = Constant Pressure
END
THERMAL CONDUCTIVITY:
Option = Value
Thermal Conductivity = 2.61E-02 [W m^-1 K^-1]
END
END
END
MATERIAL: Water
Material Description = Water (liquid)
Material Group = Water Data, Constant Property Liquids
Thermodynamic State = Liquid
PROPERTIES:
Thermal Expansivity = 2.57E-04 [K^-1]
Absorption Coefficient = 1.0 [m^-1]
Option = Value
END
DYNAMIC VISCOSITY:
Dynamic Viscosity = 8.899E-4 [kg m^-1 s^-1]
Option = Value
END
EQUATION OF STATE:
Density = 997.0 [kg m^-3]
Molar Mass = 18.02 [kg kmol^-1]
Option = Value
END
REFRACTIVE INDEX:
Option = Value
END
Option = Value
END
Option = Value
Reference Specific Enthalpy = 0.0 [J/kg]
Reference Specific Entropy = 0.0 [J/kg/K]
Specific Heat Capacity = 4181.7 [J kg^-1 K^-1]
END
Option = Value
Thermal Conductivity = 0.6069 [W m^-1 K^-1]
END
END
END END EXECUTION CONTROL:
PARALLEL HOST LIBRARY:
HOST DEFINITION: b
Installation Root = C:\CFXb\CFX-%v
Host Architecture String = intel_pentium_winnt5.1
END
END
PARTITIONER STEP CONTROL:
Multidomain Option = Coupled Partitioning
Runtime Priority = Standard
MEMORY CONTROL:
Memory Allocation Factor = 1.0
END
PARTITIONING TYPE:
MeTiS Type = k-way
Option = MeTiS
Partition Size Rule = Automatic
END
END
RUN DEFINITION:
Definition File = D:/xjj/2bubble1.def
Interpolate Initial Values = Off
Run Mode = Full
END
SOLVER STEP CONTROL:
EXECUTABLE SELECTION:
Double Precision = Off
END
MEMORY CONTROL:
END
PARALLEL ENVIRONMENT:
Number of Processes = 1
Start Method = Serial
END
END END FLOW:
DOMAIN: Domain 1
Coord Frame = Coord 0
Domain Type = Fluid
Fluids List = Air at 25 C,Water
Location = Assembly
BOUNDARY: out
Boundary Type = OPENING
Location = OUTLET
BOUNDARY CONDITIONS:
FLOW DIRECTION:
Option = Normal to Boundary Condition
END
FLOW REGIME:
Option = Subsonic
END
MASS AND MOMENTUM:
Option = Opening Pressure and Direction
Relative Pressure = 0 [Pa]
END
END
FLUID: Air at 25 C
VOLUME FRACTION:
Option = Value
Volume Fraction = 0
END
END
END
FLUID: Water
VOLUME FRACTION:
Option = Value
Volume Fraction = 1
END
END
END
END
BOUNDARY: sym1
Boundary Type = SYMMETRY
Location = FRONT
END
BOUNDARY: sym2
Location = BACK
END
BOUNDARY: Domain 1 Default
Boundary Type = WALL
Location = INLET,SURFS A,SURFS B
WALL INFLUENCE ON FLOW:
Option = No Slip
END
END
FLUID PAIR: Air at 25 C | Water
WALL ADHESION:
Option = None
END
END
END
END
DOMAIN MODELS:
BUOYANCY MODEL:
Buoyancy Reference Density = 1.185 [kg m^-3]
Gravity X Component = 0 [m s^-2]
Gravity Y Component = 0 [m s^-2]
Gravity Z Component = -9.8 [m s^-2]
Option = Buoyant
BUOYANCY REFERENCE LOCATION:
Option = Automatic
END
END
DOMAIN MOTION:
Option = Stationary
END
MESH DEFORMATION:
Option = None
END
REFERENCE PRESSURE:
END
END
FLUID: Air at 25 C
FLUID MODELS:
FLUID BUOYANCY MODEL:
Option = Density Difference
END
MORPHOLOGY:
Option = Continuous Fluid
END
END
END
FLUID: Water
FLUID MODELS:
END
MORPHOLOGY:
END
END
END
FLUID MODELS:
COMBUSTION MODEL:
Option = None
END
HEAT TRANSFER MODEL:
Fluid Temperature = 25 [C]
Homogeneous Model = True
Option = Isothermal
END
THERMAL RADIATION MODEL:
Option = None
END
TURBULENCE MODEL:
Option = Laminar
END
END
Surface Tension Coefficient = 0.07256 [N m^-1]
INTERPHASE TRANSFER MODEL:
Option = Free Surface
END
MASS TRANSFER:
Option = None
END
SURFACE TENSION MODEL:
Curvature Under Relaxation Factor = 0.25
Option = Continuum Surface Force
Primary Fluid = Water
Volume Fraction Smoothing Type = Volume-Weighted
END
END
MULTIPHASE MODELS:
Homogeneous Model = On
FREE SURFACE MODEL:
Option = Standard
END
END
END
INITIALISATION:
Option = Automatic
FLUID: Air at 25 C
INITIAL CONDITIONS:
VOLUME FRACTION:
Option = Automatic with Value
Volume Fraction = UpVFbubble1
END
END
END
FLUID: Water
INITIAL CONDITIONS:
VOLUME FRACTION:
Volume Fraction = UpVFwater1
END
END
END
INITIAL CONDITIONS:
Velocity Type = Cartesian
CARTESIAN VELOCITY COMPONENTS:
U = 0 [m s^-1]
V = 0 [m s^-1]
W = 0 [m s^-1]
END
STATIC PRESSURE:
Relative Pressure = Pres1
END
END
END
OUTPUT CONTROL:
RESULTS:
File Compression Level = Default
Option = Standard
END
TRANSIENT RESULTS: Transient Results 1
Option = Standard
Time Interval = 0.002 [s]
END
END
SIMULATION TYPE:
Option = Transient
INITIAL TIME:
Time = 0 [s]
END
TIME DURATION:
Option = Total Time
Total Time = 1 [s]
END
TIME STEPS:
Option = Timesteps
Timesteps = 0.0001 [s]
END
END
SOLUTION UNITS:
Angle Units = [rad]
Length Units = [m]
Mass Units = [kg]
Solid Angle Units = [sr]
Temperature Units = [K]
Time Units = [s]
END
SOLVER CONTROL:
ADVECTION SCHEME:
Option = High Resolution
END
CONVERGENCE CONTROL:
Maximum Number of Coefficient Loops = 15
Timescale Control = Coefficient Loops
END
CONVERGENCE CRITERIA:
Residual Target = 0.00001
Residual Type = RMS
END
TRANSIENT SCHEME:
Option = Second Order Backward Euler
END
END END COMMAND FILE:
Version = 10.0
Results Version = 10.0 END
+--------------------------------------------------------------------+ | | | Solver | | | +--------------------------------------------------------------------+
+--------------------------------------------------------------------+ | | | ANSYS CFX Solver 10.0 | | | | Version 2005.07.11-10.24 Mon Jul 11 10:26:04 GMTDT 2005 | | | | Executable Attributes | | | | single-32bit-optimised-supfort-noprof-nospag-lcomp | | | | Copyright 1996-2005 ANSYS Europe Ltd. | +--------------------------------------------------------------------+
+--------------------------------------------------------------------+ | Job Information | +--------------------------------------------------------------------+
Run mode: serial run
Host computer: B Job started: Mon Jan 14 14:29:22 2008
+--------------------------------------------------------------------+ | Memory Allocated for Run (Actual usage may be less) | +--------------------------------------------------------------------+
Data Type Kwords Words/Node Words/Elem Kbytes Bytes/Node
Real 34615.5 432.69 884.15 135216.9 1730.78 Integer 6051.7 75.65 154.57 23639.5 302.59 Character 2442.3 30.53 62.38 2385.0 30.53 Logical 40.0 0.50 1.02 156.2 2.00 Double 477.8 5.97 12.20 3732.9 47.78
+--------------------------------------------------------------------+ | Total Number of Nodes, Elements, and Faces | +--------------------------------------------------------------------+
Domain Name : Domain 1
Total Number of Nodes = 80000
Total Number of Elements = 39151
Total Number of Hexahedrons = 39151
Total Number of Faces = 79998
+--------------------------------------------------------------------+ | Buoyancy Reference Information | +--------------------------------------------------------------------+
Domain Group: Domain 1
Buoyancy has been activated. The absolute pressure will include
hydrostatic pressure contribution, using the following reference
coordinates: ( 1.50000E-03, 5.00000E-05, 4.50000E-02). ---------------------------------- Error in subroutine GET_SPECVAR : Specified values for Water.Conservative Volume Fraction are out of bounds on Domain 1 GETVAR originally called by subroutine CAL_GVar
+--------------------------------------------------------------------+ | Writing crash recovery file | +--------------------------------------------------------------------+
+--------------------------------------------------------------------+ | An error has occurred in cfx5solve: | | | | The CFX-5 solver could not be started, or exited with return code | | 255: . No results file has been created. | +--------------------------------------------------------------------+
End of solution stage.
+--------------------------------------------------------------------+ | Warning! | | | | The CFX-5 Solver has written a crash recovery file. This file has | | been saved as D:\xjj\jingzhi\2bubble1_006.res.err and may be an | | aid to diagnosing the problem or restarting the run. More details | | should be available in the solver output section of the output | | file. Note that a lock file was left for the crash file when the | | solver exited, and so it is probably incomplete. | +--------------------------------------------------------------------+
+--------------------------------------------------------------------+ | The following user files have been saved in the directory | | D:\xjj\jingzhi\2bubble1_006: | | | | mon | +--------------------------------------------------------------------+
This run of the CFX-5 Solver has finished.
Glenn Horrocks January 15, 2008 17:46
Re: error using combination of step function
The error message is saying your function is returning values which are out of bounds, that is smaller than 0 or greater than 1. Check the function to calculate the volume fraction.
