Constant pressure!
Can some body tell me how to fix a constant pressure within each cell of my simulation! Thanks
Mann |
Re: Constant pressure!
You can turn the hydrodynamic solver off, this will fix the velocity and pressure fields. You do this using an expert parameter. Is this what you want? Glenn Horrocks |
In the paper they have imposed constant pressure gradient on every cell as a driving force, with fully periodic boundary conditions at the inlet and the outlet. So basically i want to get fixed pressure of -1.59 Pa/m within every cell of my domain before i switch to periodic BC.
I will look into expert parameter tomorrow, but i only want to fix my pressure not velocity field! If you can more precisely explain how to do that it will be very helpful! Mann |
Sorry i need to obtain a fixed pressure of 0.13 Pa within every cell of my domain because my duct in 0.08m long. If anyone can explain how to do that it will be very helpful!
Mann |
It cannot be done. The pressure field is coupled to the velocity field so fixing one and allowing one to float is not physically meaningful. I would use the translational periodic boundaries with a pressure difference. This feature exists in CFX and is more physically meaningful. Glenn Horrocks |
Ok makes sense! Thank you Glenn
One more thing if i specify pressure change in Interface domain, do i need to specify initial velocity in domain initialistaion or global intialistaion.
Usman |
A sensible initial guess will improve convergence and is always a good idea. Glenn Horrocks |
