Periodic Boundary
Old   January 14, 2008, 17:47
Default Periodic Boundary
Mann
Hi
I am simulating a flow in a square duct with four cubes inside it. I want to set up a periodic boundary condition for my flow. In order to do that i first created a domain interface for inlet and outlet and set a translational peridocity as interface model. I have following questions:
1) Do i have to specify change in pressure? If yes how can i calculate it.
2) I would like to specify constant pressure gradient of -1.59 Pa m^-1. How can i do that!
Thanks for your help!!
Old   January 15, 2008, 17:51
Default Re: Periodic Boundary
1) You need to specify something to get the flow moving!
2) From your other posts it looks like translational periodicity with a pressure difference might be appropriate. If your duct is 1 metre long then my guess is the pressure drop would be 1.59 Pa. I will let you guess what the pressure drop is for other lengths.
Old   January 15, 2008, 20:24
Mann
Can i not specify constant pressure within every cell of my domain to get the flow moving. Thats what they seem to have done in the paper. But my problem is i dont quite know how to do it! If anyone out there can give any input it will be very helpful. I am using LES smagorinsky model!.
Mann
Old   January 16, 2008, 05:54
As previously stated setting a constant pressure gradient per cell cannot be done. This is especially so if you are doing a LES simulation! You need the pressure field to couple with the velocity field to get something of physical meaning.
Periodic boundary conditions happy5jump FLUENT 6 May 3, 2017 01:36
Symmetry and Periodic boundary conditions CFD_Fluent_User FLUENT 1 October 16, 2014 03:18
Problem with periodic boundary layers Phil FLUENT 15 October 2, 2000 15:56
periodic boundary conditions Ahmed Abdelwahab FLUENT 4 March 9, 2000 17:36
