Home > Forums > CFX
Result and trn files!
Old   January 17, 2008, 18:20
Default Result and trn files!
Usman
Every time i stop and re-start the solver it creates a new result (res) file. As a result i am not able to use all the trn files for animation that CFX has created in old res file. In time step selector only new trn files appear. Is there a way around this!
Regards Usman
Old   January 17, 2008, 18:26
Default Re: Result and trn files!
UnderwaterAlex
If you collect all the trn files from various starts and restarts of the same run into the same directory associated with a .res file, then CFX-Post will automatically load them when it loads the .res file.
Old   January 17, 2008, 18:43
Usman
CFX automatically creates a new folder every time i re-start the solver because it creates a new res file. Do you mean i should copy and paste all the trn files in my very last res folder!
Thanks Usman
Old   January 17, 2008, 18:53
UnderwaterAlex
Exactly.
Old   January 18, 2008, 12:32
Default Enough with the exclamation points ! ! !
CycLone
Is everything you do urgent!!!!
Old   January 18, 2008, 13:42
Default Re: Enough with the exclamation points ! ! !
Usman
Yeh kind of! If it annoys you Cyclone i wont do it anymore. Happy!
Regards Usman
Old   January 18, 2008, 13:56
Usman
On a more serious note cycLone, i wish you could visit the CFX forum more often because your answers really help the beginners like myself.
Usman
Old   January 21, 2008, 09:43
Phil
Or use the 'load additional files' option from the timestep selector in Post to load all the previous trn files...
Old   January 21, 2008, 18:10
CycLone
I'm glad to be of help and participate when I can.
Old   January 21, 2008, 18:16
Usman
Thank you phil
Usman
Old   September 27, 2013, 21:38
Ricardo Vicente de Paula Rezende
rezendervp is on a distinguished road
The last release 12 and 12.1 (I'm not right about 13, 14 and 14.5 releases) the simple copy and paste into the new res folder no longer works better. The trn now contains the trn files of the run just to avoid the copy and past of large data, and the last is no longer available. But sometimes CFD-post does not link all res folders. If the simulation crash and you restart, certainly it does not work. ( Verify if in the Load Case the option " Load complete history as A SINGLE CASE" is checked)
You also can try to Add time steps in Timestep Selector, but generally not works properly. This is a bad trouble if you try to post processing using Ensight, only files of the run will be load. ANSYS has developed a fix tool do work around this. CombineTRNinfo.exe is the tool. It write the last trn information into the next res file, so the copy and past trn into new folder will work again, and you can post processing using Ensight if you want. Ask for the ANSYS customer support to acquire the .exe.
rezendervp is offline   Reply With Quote
Thread Tools
Trackbacks are On
Post Processing Partial Result files Sans CFX 6 September 27, 2013 21:24
transient simulation result file (.trn) ? amine CFX 3 June 14, 2008 05:01
How do i calculate an average result from a transi cfxr CFX 1 April 18, 2008 11:12
how to recover trn files after crash? pi CFX 4 August 25, 2004 05:45
CFX5.5 Solver Sara CFX 8 July 12, 2002 06:49
