-   -   Reset LES statistics (http://www.cfd-online.com/Forums/cfx/25077-reset-les-statistics.html)
Usman January 21, 2008 16:16
Hi
How can i re-set my LES statistics. Am i suppose to delet old statistics and then create new ones or do i just click "Add new item" and create "Transient statistics 2". How does it work?
I am doing this because my RMS values are higher than experimental values. I am assuming it is so because my RMS values have not yet reached steady state.
Thanks for help Usman
CycLone January 21, 2008 18:17
Re: Reset LES statistics
Hi Usman,
You can either create a new Transient Statistics output object (and disable the old one by setting the iteration limits), or you can interpolate your existing solution onto a new def file at startup.
Resetting the statistics won't reduce your RMS values though. It sounds like you need to run the simulation out longer. I assume you are referring to the RMS values of the statistics, not the residuals. Right?
-CycLone
Usman January 21, 2008 18:33
Hi Cyclone
Yes i am referring to rms values of statistics. I seem to have re-set the statistics right by setting up the iteration limits.
I am simulating a LES solution on a duct with four ribs inside. My mean velocity profiles match exactly with DNS and experimental data but i am getting rms values a bit too high. I thought running the simulation for longer with new rms values would solve the problem. This is why i have re-set statistics. Am i heading in right direction?
Thanks for your reply Usman
