ICEM CFD: Tri MEsh
Hi, Is there any tutorial example for generating 2D triangular mesh in ICEM CFD? I wanna generate 2D surface triangular mesh and and then do extrusion with 1 layer.
I also need to specify some mesh density on some specific regions. Can anybody help me about this? Thanks in advance. |
Re: ICEM CFD: Tri MEsh
No there is no tutorial for generating 2D triangular mesh. You can specify mesh density in your chosen regions by selecting density option. You can click on help when you select density option, its all explained there.
Usman |
You can generate 2D Tri mesn by the surface meshing. Tri will be selected in the mesh type tab.
There is a pdf file on Emule program, called "Ansys ICEM CFD 10.0 Manual.pdf", of 17.4 MB.
can u please give me information where can i find this manues
emule
