Need LES simulation knowledge / reference material |
January 23, 2008, 22:26 |
Hi there,
I have used Reynolds average turbulence models till now. Now I need to use LES for my simulations. There seems to be so many things which I need to know in order to run a proper LES simulation. For example judging RMS values, mean values, when to stop the simulation, how to do time step averaging etc....I could not find this practical information in manual. I looked at most of the threads related to LES but could not locate a good reference material. May be I overlooked useful stuff.... Could some one brief me about LES or direct to reference material? I will be very thankful. Kind regards, Sam |
January 24, 2008, 16:33 |
Re: Need LES simulation knowledge / reference mate
While it is not a complete reference for LES, "Turbulence Modelling for CFD" by Wilcox has a very good discussion of most of the basic issues. A good place to start. Glenn Horrocks |
January 24, 2008, 18:31 |
Hi
This book mainly deals with RANS modelling and has very little on LES. I am also looking for a good LES book but so far i have found none. I personally would recommend "An Introduction to CFD" by Henk Kaarle Versteeg. If you can get hold of its latest edition it has a good introductory chapter on LES from CFD point of view. Usman |
January 25, 2008, 10:03 |
If you are looking for a more detailed reading, I can suggest the following book: "Large eddy simulation for incompressible flows" from Pierre Sagaut.
January 25, 2008, 11:34 |
Hi Magnoli
Does it have a good introductory material on LES and how good is it from CFD point of view? Usman |
January 25, 2008, 12:06 |
Hi Usman, This is a very complete book, it includes the basic concepts also. The only problem is that it can sometimes become a tyring reading.
January 25, 2008, 13:32 |
Thank you Magnoli.
Usman |
January 25, 2008, 16:30 |
Thanks
Thank you all very much for such useful information... Regards, Sam
OpenFoam-1.7.x on Suse 11.2 (64bit) does not compile | val46 | OpenFOAM Installation | 4 | August 27, 2010 03:43 |
Constant velocity of the material | Sas | CFX | 15 | July 13, 2010 08:56 |
OpenFOAM on MinGW crosscompiler hosted on Linux | allenzhao | OpenFOAM Installation | 127 | January 30, 2009 19:08 |
G95 + CGNS | Bruno | Main CFD Forum | 1 | January 30, 2007 00:34 |
