Home > Forums > CFX
how to measure the additional variable at outlet
Old   January 28, 2008, 01:17
Default how to measure the additional variable at outlet
sherkhan
I am using CFX11. Can anybody help me that how to find the additional variable %mass(kg) which leave the outlet at a specific time in a transient solution
Old   January 28, 2008, 05:03
Default Re: how to measure the additional variable at outl
Rikio
Some functions can be obtained from the function calculator. Is the %mass mean mass fraction? If so, you can obtain the massflow of outlet for each component, and then calculate manually or using customer defined variable.
Old   January 28, 2008, 07:49
sherkhan
Thanks Rikio, My problem is that i run the simulation 1st for steady state and then use these results for transient rum. I selected monitor points at inlet and outlet to monitor the concentration of additional variable (kg m^-3. But when I output data from solver the conc. at monitor pt1(inlet) is 0.98 (kg m^-3) but at outlet the conc. is only 0.06(kg m^-3). Is something wrong with my setting?? How can I take the X percent(any percent) of additional variable at outlet. Please any body help
Old   January 30, 2008, 04:34
Andreas
At first you should check your imbalances, i.e. whether (especially in your steady-state simulation) the amount of your additional variable coming in at inlet is also coming out; otherwise you still need more iterations.
Then, is concentration is in kg/m^3 it is a concentration density, and you can directly compare this with fluid density. Take the function calculator in CFX-Post and calculate areaAve of concentration at outlet divided by areaAve of density at outlet, then you have the ratio; multiply with 100, then you have percentage.
Old   January 30, 2008, 21:39
sherkhan
Thanks andreas, But there is still problem that i can not see in CFX post the function variable Concentration. Please have a detail look
The tracer at the inlet was added by the following eq. ExpFunction= fc*(1/(1+exp(-alpha*(t-sher ))))*(1-1/(1+exp(-alpha*(t-sher )))), alpha= 0.5[s^-1], fc = 1[kg m^-3], sher = 15[s], mass flow rate at inlet = 0.005kg s^-1, mass flow rate at outlet = 0.005kg s^-1, The solution was run for 20000s as transient and convergence level is 10^-6. but i can not get the percentage of mass flowing away the outlet. please help
Thread Tools
Trackbacks are On
calculation of additional variable in multiple domain cosine CFX 12 April 24, 2016 12:51
Additional Variable tav98f CFX 3 April 28, 2011 12:33
emag beta feature: charge density charlotte CFX 4 March 22, 2011 10:14
Variable outlet Badri CFX 0 January 30, 2007 01:11
Additional variable? Tuks CFX 4 October 25, 2005 15:24
