Home > Forums > CFX
LES time step
Old   January 28, 2008, 14:19
Default LES time step
Chris
Hi
If you are running a LES simulation with CFX which is a fully implicit code then how would you choose your time step. Thank you
Chris
Old   January 28, 2008, 17:59
Default Re: LES time step
Either do a mesh independence check (this can be tricky with LES), estimate a timestep based on the flow timescales or just try the recommended 3-5 iterations per timestep and see if the final results are OK.
Old   January 28, 2008, 18:08
Chris
What do you mean by flow time scales. By iterations do you mean coefficient loops? I can only check final results once i have run my simulation for a week. This is not a good option. Is there something else that you can recommend.
Chris
Old   January 29, 2008, 19:31
Flow time scales - LES simulations typically resolve the turbulent eddies down to the inertial sub-range. Therefore you need to resolve to this frequency and filter out the inertial sub-range.
Iterations/coefficient loops - yes, I mean the same thing.
Old   January 31, 2008, 12:37
Magnoli
A common guideline for LES is to keep the CFL number below 1.0. You can find even more rigorous guidelines recommending CFL ~ 0.5. The CFX manual also recommends this range. In several papers, researchers claim to have used CFL between 0.4 and 0.8. If you cannot afford such small time steps, maybe you could consider switching to SAS, but then you have to carefully evaluate if your transient results quantitatively correspond to reality, because there may be a tendency to damp the turbulent effects.
Regards, Magnoli.
Old   January 31, 2008, 20:36
CFD newbie
Thanks for your answer Magnoli. We can fix the max courant number to whatever value we like under simulation type form. However this still does not give us our time step. How can we calculate time step?
In my current simulation i have fixed the max courant number to 0.5 and am using adaptive time step, but still i had to put an initial value for time step. How do we find an initial time step then, if we use adaptive time stepping.
CFD newbie
Old   January 31, 2008, 20:43
CFD newbie
If person who initially posted this message have understood how to calculate LES time step and could share his understanding with me, it will be very helpful.
CFD newbie
Old   February 5, 2008, 12:23
Magnoli
Personally I don't like to use automatic or adaptive time steps, I prefer to specify the time step and take the decision. If you you want to base your simulation in the CFL number (following the guideline for LES), you can run the simulation for a few time steps, check the CFL number and set it to a new value, adequated to your simulation. About how to calculate the time step, I don't know any relation which would be valid for all cases (except this guideline for LES), or which is only dependent from your numeric setup. You should use your knowledge of your physical problem and the oscillation frequencies, you're expecting to observe, as an intial guess for your time step. I usually use 1/20 of the expected characteristic period as the time step. After a first simulation I would additionally vary the time step and check its influence on the solution, to be sure that you achieved a time step independent solution. If you have no idea of what time step to start with, I would suggest that you take a further look at the physical nature of your problem. You should also evaluate your real need for LES or if DES or SAS would be good enough.
Regards, Magnoli.
Thread Tools
Trackbacks are On
SLTS+rhoPisoFoam: what is rDeltaT??? nileshjrane OpenFOAM Running, Solving & CFD 4 February 25, 2013 05:13
Time step, Number of time step, Maxximum Iterations per time step sandisk FLUENT 0 July 18, 2011 02:57
Is there a way to write the time step size, time a may FLUENT 6 November 22, 2009 12:52
Problems with simulating TurbFOAM barath.ezhilan OpenFOAM 13 July 16, 2009 05:55
VOF özgür FLUENT 8 January 6, 2004 09:23
