Overflow help
Old   February 3, 2008, 22:36
Default Overflow help
zaxzax
This is a simple simulation. There is a water tank with one outlet. I set up a source point in the middle of the tank to simulate the glycol leaking into the tank. The glycol is set by using an additional variable. The purpose is to know the flow rate of glycol at the outlet. However, when I run the solver,it showed that a wall has been placed at the outlet to prevent the water flow into the domain. And after several iterations it stopped with fatal overflow error.Can anybody tell me what's wrong?
p/s:If I setup an inlet instead of a source point. There was no error.
overflow during writing result adam2008 CFX 2 March 21, 2011 09:11
Solution variables goes outside upper limit -how to localize fatal overflow occurance Dimone CFX 2 January 21, 2011 07:35
Floating-point Overflow 0xc0000091 causes? JohnGane1987 Main CFD Forum 0 April 8, 2010 10:53
OVERFLOW and Horizontal Axis Wind Turbine ntonkin Main CFD Forum 1 November 19, 2009 02:40
linear solver overflow peggy CFX 1 February 8, 2001 02:39
