February 2, 2008, 09:23 |
license error
Dear CFX user..
i have installed ANSYS CFX 11 SP1 version in linux machine.. now i am getting license check out failed error, when opening the def. file in CFX pre. But there is no problem in running ansys license manager. it is running properly and shows available license status. and also getting the following the errors in CFX solver ERROR #001100247 has occurred in subroutine . | | Message: | | The solver is unable to continue because of licensing problems. | | | | A license for the following capability level could not be checked out: | Node Limited Basic Capability Solver | Please carefully examine the error message output above and check | 1) LM_LICENSE_FILE points to the correct license server | 2) The ".flexlmrc" file points to the correct license server | 3) The required capabililty exists on the license server | 4) The license server is up and running. with regards cfdtest |
February 3, 2008, 16:43 |
Re: license error
Check the license manager to see if the solver is checked out. Sometimes the licenses do not check themselves back in again properly. Check the license manager log file, that may also help. 99% of licensing problems like this are fixed by shutting the the license server machine down and starting up again. A bit brutal and it can be done far more elegantly if you know how to drive license servers but it works and is simple. Glenn Horrocks |
February 4, 2008, 09:39 |
Re: license error
cos you are using cracked license,
disinstall Flexlm COMPLETELY, reinstall |
February 5, 2008, 04:53 |
Re: license error
Dear friends..
i don't have crack version.. i have reinstalled the FlemLM after complete uninstall of FlexLM still i am not able to run.. regards CFDUSERIN |
February 21, 2020, 14:57 |
License Manager Problem
Rep Power: 11 |
Hi guys,
I have a question about License Manager of Ansys. I have recently registered and installed a student version of Amesim and faced the below problem about License Manager: ------------------------------------------------------- AMESim - License Error Failed to connect to the license server. LMS_LICENSE is currently set to: 5053@localhost. This license server is not available or does not exist. license server error: (12) RLM: Cannot connect server 5053@localhost reported for feature "test_connection": Communications error with license server. (RLM error -17) ------------------------------------------------------- Could it be because of Ansys License Manager preventing Amesim from running? |
February 21, 2020, 16:14 |
Rep Power: 143 |
You have to make sure the ANSYS license server and AMESIM license server are operating on different ports, and are on compatible versions of flexlm.
February 22, 2020, 00:58 |
Rep Power: 11 |
CGNS Compiling | Diego | Main CFD Forum | 17 | December 21, 2014 01:40 |
nonNewtonian viscosity model | mhassani | OpenFOAM Programming & Development | 5 | January 7, 2013 09:27 |
c++ libraries and solver compiling | vaina74 | OpenFOAM Installation | 13 | February 3, 2012 17:43 |
CGNS lib and Fortran compiler | manaliac | Main CFD Forum | 2 | November 29, 2010 06:25 |
Problem with compile the setParabolicInlet | ivanyao | OpenFOAM Running, Solving & CFD | 6 | September 5, 2008 20:50 |
