February 3, 2008, 08:14 |
LES of Non-Premixed Combustion in CFX??
Hi Robin and Glenn, Just curious to know why i cant combine LES Samagorisky Model and Eddy Dissipation Model for a non premixed combustion problem in CFX? Is CFX unable to do LES for such problem? However support says SAS is capable enough to give results like LES. But i am not satisfied. Can you please throw some light on it. Thanks in advance.
Manu |
February 3, 2008, 16:35 |
Re: LES of Non-Premixed Combustion in CFX??
I have no experience in using the Eddy Dissipation model in LES, but I can't see why you can't use it with LES. What is telling you that you cannot use it? Glenn Horrocks |
February 4, 2008, 03:09 |
Hi Glenn, When you select both( EDM and LES) of them and press ok. After that if you reopen to see whether they are there or not i always find k-e has replaced the LES Samagosrinsky model. This is what the problem is. regards Kirti
February 4, 2008, 16:30 |
I would talk to CFX support about this. It may be a bug in CFX-Pre. You can tell the solver to use EDM and LES via the CCL anyway if you want to over-ride CFX-Pre. Regards, Glenn Horrocks |
February 22, 2008, 11:18 |
In their standard formulations these models are not combineable. The reason is not a bug in CFX but the theory of both models. Have a look at the theory manual of CFX or the literature (famous old paper of Spalding). The EDM reaction rate depends on turbulent kinetic energy and its dissipation. How do you define these quantities in LES?
February 25, 2008, 16:34 |
Good point! Glenn Horrocks |
Premixed combustion model - FLUENT | Mowan | FLUENT | 10 | September 23, 2023 01:56 |
urgent!!! please...about Premixed Combustion | mesinUGM | FLUENT | 6 | March 30, 2012 09:22 |
Non-adiabatic Premixed combustion through scriptin | Mahesh | Main CFD Forum | 2 | April 1, 2007 01:04 |
LES - Premixed combustion. | Interested. | Main CFD Forum | 9 | July 16, 2005 07:09 |
Does CFX support LES, local dynamic mdoel | JJ | CFX | 0 | August 28, 2003 21:15 |
