February 8, 2008, 11:25 |
Surface roughness
Hi
can we have surface roughness and Yplus cell height which is less than the surface roughness cell height for a No slip wall in CFX,is there any best practices. thanks in advance |
February 10, 2008, 16:36 |
Re: Surface roughness
Numerically it should cause no problems and run fine. Whether it has any physical significance - that is whether it is accurate or not is a matter of debate and probably depends on exactly what you are modelling. Glenn Horrocks |
nutRoughWallFunction and Surface Roughness Documented | AlanR | OpenFOAM Programming & Development | 64 | January 6, 2024 07:13 |
[Gmsh] Error : Self intersecting surface mesh, computing intersections & Error : Impossible | velan | OpenFOAM Meshing & Mesh Conversion | 3 | October 22, 2015 11:05 |
[Gmsh] Problem with Gmsh | nishant_hull | OpenFOAM Meshing & Mesh Conversion | 23 | August 5, 2015 02:09 |
Surface roughness | alefem | FLOW-3D | 6 | June 3, 2010 12:49 |
CFX4.3 -build analysis form | Chie Min | CFX | 5 | July 12, 2001 23:19 |
