February 12, 2008, 14:16 |
gravity additional variable
How can I simulate the settling of a tracer (additional variable) under gravity in a viscous fluid? It seems that I can not make the fluid density a function of the AV. Thanks! |
February 12, 2008, 18:22 |
Re: gravity additional variable
I figured it out... need to define a fluid with variable composition mixture. Then add two fluids. One fluid is the fluid with a density equal to the original fluid, the other one is the fluid including the additional density of the tracer. Then activate buoyancy, constraint the original fluid and include kinematic diffusivity for the tracer. Then there is no need for an additional variable. Anyway, this seems to work well, but suggestions are welcome.
Additional Variable | tav98f | CFX | 3 | April 28, 2011 12:33 |
emag beta feature: charge density | charlotte | CFX | 4 | March 22, 2011 09:14 |
Problems with additional variable | Krishna Premi | CFX | 1 | October 29, 2007 08:19 |
Multi_component Vs Additional Variable | Anurag | CFX | 2 | February 4, 2005 16:45 |
Replace periodic by inlet-outlet pair | lego | CFX | 3 | November 5, 2002 20:09 |
