Setting Roughness on a Solid-Fluid Interface
Old   February 7, 2008, 12:11
Default Setting Roughness on a Solid-Fluid Interface
JensonButton
In a CHT simulation, is it possible to set roughness on the solid side of interface? If the answer is yes, how ? Thak You.
Old   February 7, 2008, 13:41
Default Re: Setting Roughness on a Solid-Fluid Interface
opaque
Dear JensonButton,
The roughness is set on the fluid side of the interface.. The solid side is within the solid and the roughness has no meaning then.
It is just interpretation on what a side means,
Hope it helps,
Opaque.
Radiation at interface between fluid and porous domain Hitch8 CFX 19 April 20, 2015 06:24
Re-meshing a deformable solid body in a fluid brashear CFX 6 December 12, 2011 11:13
solid to fluid heattransfer with chtMultiRegionFoam nakor OpenFOAM 11 March 21, 2011 08:28
solidWallHeatFluxTemperature at the solid solid interface in chtMultiRegionSimpleFoam maddalena OpenFOAM Running, Solving & CFD 43 January 11, 2011 02:39
Cells with t below lower limit Purushothama Siemens 2 May 31, 2010 21:58
