-   -   Changing default values (http://www.cfd-online.com/Forums/cfx/25189-changing-default-values.html)
dcwnj February 6, 2008 15:39
I was wondering if there is a way of changing the default values for CFX on a couple of things. For instance, the default domain - reference pressure defaults to 101325 Pa. I would like to default several things like that differently. Any one know how to do that?
opaque February 6, 2008 16:46
Re: Changing default values
Dear dcwnj
If you do not mind messing around with the installation, you can modify the [install_directory]/etc/RULES file.
Search for
PARAMETER: Reference Pressure
and change the default value from 1 [atm] to whatever you want.
Not all the default values are in that file. Some are in the [install_directory]/etc/CFXPrePhysics.ccl file as well.
As usual, before modifying original files you must back them up in case you something goes awfully wrong.
Opaque.
