February 6, 2008, 14:39 |
Changing default values
I was wondering if there is a way of changing the default values for CFX on a couple of things. For instance, the default domain - reference pressure defaults to 101325 Pa. I would like to default several things like that differently. Any one know how to do that?
February 6, 2008, 15:46 |
Re: Changing default values
Dear dcwnj
If you do not mind messing around with the installation, you can modify the [install_directory]/etc/RULES file. Search for PARAMETER: Reference Pressure and change the default value from 1 [atm] to whatever you want. Not all the default values are in that file. Some are in the [install_directory]/etc/CFXPrePhysics.ccl file as well. As usual, before modifying original files you must back them up in case you something goes awfully wrong. Opaque. |
default values of kOmega (Wilcox) different from paper | romant | OpenFOAM Running, Solving & CFD | 2 | August 3, 2011 06:43 |
Monitor Points values in CFX-Solver | Silmaril | CFX | 1 | March 10, 2011 08:48 |
Interpolation values in nodes and cells | mrestrepo30 | FLUENT | 0 | April 27, 2010 09:20 |
Why's FLUENT changing the reference values? | siw | FLUENT | 0 | November 6, 2008 13:17 |
Reference Values Help | Sham | FLUENT | 0 | February 26, 2005 08:43 |
