Surface roughness
Old   February 8, 2008, 11:25
Default Surface roughness
Rajesh
Hi
can we have surface roughness and Yplus cell height which is less than the surface roughness cell height for a No slip wall in CFX,is there any best practices.
thanks in advance
Old   February 10, 2008, 16:36
Default Re: Surface roughness
Numerically it should cause no problems and run fine. Whether it has any physical significance - that is whether it is accurate or not is a matter of debate and probably depends on exactly what you are modelling.
nutRoughWallFunction and Surface Roughness Documented AlanR OpenFOAM Programming & Development 64 January 6, 2024 07:13
[Gmsh] Error : Self intersecting surface mesh, computing intersections & Error : Impossible velan OpenFOAM Meshing & Mesh Conversion 3 October 22, 2015 11:05
[Gmsh] Problem with Gmsh nishant_hull OpenFOAM Meshing & Mesh Conversion 23 August 5, 2015 02:09
Surface roughness alefem FLOW-3D 6 June 3, 2010 12:49
CFX4.3 -build analysis form Chie Min CFX 5 July 12, 2001 23:19
